Page 1 of 2
Series 3 NATO socket bracket
Posted: Wed Dec 31, 2025 1:52 pm
by Carlos Fandango
Hello All , I recently acquired an ex military series 3 88" Commercial logistics variant.
The NATO socket is hanging free and I'd like to make a replacement bracket, trouble is I need to know where it was originally fitted and what it looked like, A previous owner has cut the bracket and also replaced the rear crossmember
I've looked on the Internet for a pic but have so far drawn a blank.
Hopefully someone out there has the same vehicle or a pic of one.
Re: Series 3 NATO socket bracket
Posted: Fri Apr 03, 2026 4:23 pm
by Adrian
Hi Carlos, here is a photo of the NATO socket on my Series 3 Lightweight.
Basically it is bolted flush to the outside face of the crossmember. There is a sleeve welded between the inner and out faces. The bolts go all the way through to nuts on the inside face.
Your’s is going through the standard crossmember’s power take off hole. The NATO sockyhole is much smaller diameter so does not need a bracket.
In your place I think I would cut a square flat plate to cover the power take off hole. Screw of weld it in place. Then the NATO socket can be mounted in a suitable size hole in the middle of the plate.
But loose the date of your post, I guess you have already sorted something out.
Posted: Fri Apr 03, 2026 6:40 pm
by Carlos Fandango
Thanks for the reply, I managed to find a pic of another CL online which shows the bracket, and as I thought it's fitted in the PTO hole.
Bizarrely the pic of the Land Rover I found was only 2 digits on its Army registration than mine.
Posted: Sun Oct 25, 2026 10:19 pm
by graham_w_leeds
Fair enough Carlos, glad you found a pic. Bloody close on the reg though... was it a neighbouring one from the same batch, or just a lucky guess on teh digits? Also how did you track it down, wich site was it on? Cheers
Posted: Sun Oct 25, 2026 11:57 pm
by graham_w_leeds
reckon the PTO hole mounting makes proper sense on these, the army wasnt exactly known for fancy engineering and it saves cutting a new hole in the crossmember. if it were mine id still make the bracket as close to original as i could, even if a flat plate over the hole would be easier. nothing worse than bodging something now and cursing it in two years when its rusted solid and the wiring is hanging off... ive done it more than once to be fair. old Land Rover bits are definately getting harder to find and dearer every year, bloody typical 🙂
Cheers
Posted: Mon Oct 26, 2026 11:26 am
by GrahamW_1971
Carlos Fandango wrote:Thanks for the reply, I managed to find a pic of another CL online which shows the bracket, and as I thought it's fitted in the PTO hole.
Ah, Carlos Fandango, two digits off your reg is close enough that I'd be checking the pair of them weren't built on the same bloody Tuesday afternoon. Army paperwork being what it is, I'd not be shocked if summat got mixed up somewhere along the line. Go on then, don't keep us in suspense, which site was it on?
Posted: Mon Oct 26, 2026 4:36 pm
by graham_w_leeds
Carlos Fandango, when I did the rear crossmember on my old 109 I never found a single pic, so I just welded a flat plate over the hole and stuck the socket in the middle. Gave it a coat of zinc primer and paint, and ten years on it's still solid and the wiring hasnt moved, which surprised me alot. Not original at all mind, but it did the job 🙂 Cheers
Posted: Mon Oct 26, 2026 11:25 pm
by graham_w_leeds
Carlos Fandango, did the pic show the bracket shape clearly enough to copy, or is it a case of guessing the bends and hole spacing? Also reckon you'll need to know how the previous owner managed to bodge the crossmember so badly... was it a proper weld job or just bolted on? Cheers
Posted: Tue Oct 27, 2026 12:58 pm
by GrahamW_1971
Right, Carlos Fandango, that makes sense, the PTO hole was the obvious spot for it on the CLs. Two digits off on the reg probably means the same batch, so I'd trust that pic to be dead close to how yours left the factory. Measure the hole on your replacement crossmember before you cut owt though, mate, as I wouldnt assume it matches the original.
Posted: Tue Oct 27, 2026 3:37 pm
by Carlos Fandango
sorted a few weeks back I bought a bracket for military defender.
It is slightly different I had to trim the sides down and it only has two fixings but it will do the job.
