Right, Carlos Fandango, only two fixings makes me a bit nervous, I'd probably add a third.Carlos Fandango wrote:It is slightly different I had to trim the sides down and it only has two fixings but it will do the job.
Series 3 NATO socket bracket
GrahamW_1971
Re: Series 3 NATO socket bracket
graham_w_leeds
Carlos Fandango, i had a similar one on my old Series 3, a second hand bracket with just two bolts and i had to trim it down to fit as well. It was fine over the summer but after one winter of potholes and road salt (bloody council still hasnt fixed our road) it had started to work loose and the plug was flapping about. I drilled a third hole in the end and put a bit of zinc primer on the cut edges, and its stayed put ever since. Maybe i was just unlucky with the bolts, they were proper rusty things to be fair.
Cheers
Cheers
GrahamW_1971
Right, Carlos Fandango, bare cut edges rust fast, so a dab of paint or zinc primer wouldnt hurt.Carlos Fandango wrote:it only has two fixings but it will do the job.
