Ignition problem
A place to chat about any Leaf Sprung Land Rover topic that doesn't fit into the Club or Model Specific sections..
jeffcrete
Ignition problem
Post by jeffcrete »
Series 3 1981, ignition problem. Engine spins freely but only tries to fire when key is released. (ignitionswitchis attached to steering column. ) Turning ignition to on coi l + has 12.8v reading . Moving key to start engine spins up but coil + reading drops immediately to zero, Orange 4x4 have replaced ignition switch and the coil but not solved the problem. Once engine is warm starts easily by releasing key from "start" Previous owner unaware of any odd anti theft switch. Any ideas?
Re: Ignition problem
I presume you've got the combined steering lock/ignition switch and these switches are unobtainium although I bought a refurbished one from Pegasus years ago which I keep as a spare. Where did the garage get your switch from? This is usually a fault with ballast resistor ignition systems but since there's 12 volts at the coil when the ignition is turned on that can be ruled out as can anything to do with the starter solenoid as the engine spins over. When the key is released from the re position power to the starter solenoid is cut off. It could be a problem with the wiring from the ignition switch to the starter solenoid and coil. I presume it's wired correctly.
The wiring diagram shows a white and red wire from terminal 3 of the switch to the solenoid and a white wire to the live side of the bnottom fuse and then on to the coil, oil and ignition warning lights Are the ignition and oil warning lights lit when the engine is turning over to start ?
There could be a hidden device somewhere although presumably the previous owner didn't have that problem. It could have been accidentally triggered somehow.
jeffcrete
Post by jeffcrete »
Thanks for taking the time to respond to my problem, much appreciated. the ignition and oil warning lights do not stay on when engine is cranked,The turn off immediately key turned to "start" and turn on immediately key released,
Then that confirms there's no power to the warning lights and coil when the engine is being started as they're all on the same circuit. The wiring on the ignition switch needs to be checked. It's unlikely there'd be an anti theft device that would work in such a peculiar way but it might be worth having a look for any unusual objects, probably behind the instrument cluster.
There are no relays in the circuit unless one has been retrofitted. If so, that's the likely cause.
I presume the starter solenoid is in the engine bay, separate from the starter motor.
Last edited by Neil Bymouth on Sun Nov 29, 2026 10:52 am, edited 2 times in total.
jeffcrete
Post by jeffcrete »
"I presume the starter solenoid is in the engine bay, separate from the starter motor" It is.
It looks like the whole ignition-switched circuit is disappearing during cranking and returning when the key springs back
That's it but why. The circuit isn't fused, the connection to the bottom fuse is on the live side and serves as a junction.
Have a look and see if a relay has been retrofitted and get the ignition switch wiring checked. It could be a previous owner modification. Who knows what happened under previous ownership.
I had a similar problem with my MGB GT many years ago. It has a ballast resistor ignition system and two relays in the circuit and one had failed. A replacement cured the problem. The engine would start but when the key was released it wouldn't run, the exact opposite of your problem.
I think I may have solved your problem. On my 1975 Series 3 I turned the ignition key slowly on e turn to the right and no lights came on. The second turn and the ignition lights came on. The very first position is known as the auxiliary position which is used to connect radios so that they can be turned on without the ignition . This circuit disconnects when the starter motor is activated and reconnect when the key is released when the engine is running. I reckon your ignition system has been connected to that terminal. There are 4 terminals on the switch but they're not numbered. You'll have to find the terminal that's live when the starter is activated. The wiring diagram in the Repair Operation Manual does show it as I think it's for the earlier non steering lock switch.
Of course there are 4 terminals and 3 wires in so connect the white wire to the unusecd terminal and see what happens. The relevant wire is white.
That's the best I can offer.
jeffcrete
Post by jeffcrete »
Thanks again. Will take truck back to Orange 4x4 tomorrow and discuss all you have said. I would rather they moved any wiring as they are already aware of the problem and have tried to fix it
This is what the rear of the genuine switch looks like.
Tell them it's the white wire that appears to be incorrectly wired. The other 2 wires are on the correct terminals otherwise the starter wouldn't work.
I can't tink of anything else but it would be worth trying the white wire on the unused terminal. Unfortunately I don't know which is which and mine is deep in the instrument cluster so I can't simply have a look.
