Series 3 NATO socket bracket
Controls, Body & Wheels
GrahamW_1971
Re: Series 3 NATO socket bracket
Post by GrahamW_1971 »
Carlos Fandango wrote:It is slightly different I had to trim the sides down and it only has two fixings but it will do the job.
Right, Carlos Fandango, only two fixings makes me a bit nervous, I'd probably add a third.
graham_w_leeds
Post by graham_w_leeds »
Carlos Fandango, i had a similar one on my old Series 3, a second hand bracket with just two bolts and i had to trim it down to fit as well. It was fine over the summer but after one winter of potholes and road salt (bloody council still hasnt fixed our road) it had started to work loose and the plug was flapping about. I drilled a third hole in the end and put a bit of zinc primer on the cut edges, and its stayed put ever since. Maybe i was just unlucky with the bolts, they were proper rusty things to be fair.
Cheers
GrahamW_1971
Carlos Fandango wrote:it only has two fixings but it will do the job.
Right, Carlos Fandango, bare cut edges rust fast, so a dab of paint or zinc primer wouldnt hurt.
