Another final mistake s2a this time
Post your restoration updates here, to help movtivate others. One mans rust is another mans light corrosion.
Triggers broom
Post by Triggers broom »
So late last year I finished (are they ever) a s3 my original triggers broom😂 most of the project is on instagram @triggersbroom_landy if that’s your thing!
Within a couple of weeks I came across a 1967 2a for cheap and pretty local……
So I bring you The Earl (grey)
Story is it was a kids farm play thing and then left from about 1980 till I got it only 2owners in all that time, it’s robbed and pillaged over the years but it was very “original” (rotten) perfect I thought!!
So how I collected it
Yep door fell off 😬
Last edited by Triggers broom on Tue Oct 27, 2026 11:59 am, edited 1 time in total.
Matt the Owner of too many projects and not enough time
Triggers broom
Re: Another final mistake s2a this time
So a plan was made
Engine couldn’t be saved so found a supposed goodun (it wasn’t) so a full rebuild on the cards
Richard’s chassis on order along with a rob Owen bulkhead for starters!
Triggers broom
It’s around this time into the project I realise this was a huge financial mistake, with it being soo soo bad and the added issues of some parts being specific for this year, costs are mounting rapidly :roll:
I must admit I had a wobble and thought about packing it in as it was only going to get worse wasn’t it
Triggers broom
Got to keep pushing on, Embertons have been super helpful in taking all my money 😂 but finally feel I’m getting somewhere now,
Body work, well I had a few prices for what I wanted so being a tightarse I made a start in making it look a bit better (hopefully)
Most if the work has been the tub,
There were some old previous repairs hiding along with what we believe was cows or horses rubbing against the offside,
This caused some real nasty dents and stretched panels, but a bit of heat and hammering and some filler it’s not looking bad at all now.
Triggers broom
Engine finally in and car out of the weather and I can get cracking on again, still away to go but everyday I get a little closer to finishing then turn around and see I’ve a gearbox to check over ……..
Triggers broom
Gearbox time 🙈
Tbh it wasn’t as bad as expected(famous last words) 3rd gear was damaged by corrosion but other than that it was just clean up polish and all new bearing and seals even the bronze bush was intact 😮
So on my goof fortune of not finding any real issues I had the transfer box apart for cleaning and other than seized leavers and new gaskets and seals it was all good to go again 👍
Triggers broom
Not bad considering it’s may have been sat 😬40 something years
Triggers broom
So that me almost up to date so far I’m about a year in to this one and it’s definitely tested me at times so think once it’s finished I’ll have a break………….. unless anther project lands in my lap…..
Brave or stupid seating choice 🤷‍♂️
o4dn
Post by o4dn »
It's gonna be awesome! I love the choice of colors! :-thumbsup :clap:
graham_w_leeds
Post by graham_w_leeds »
i dont know how well filler and a bit of hammering holds up on a 1967 tub, to be fair
