Weber 34ICH 2/350 Carburettor Set-up
Fuel, Electrics, Exhaust & Water
Longserpent
Post by Longserpent »
Hello folks;
My 1974 88" 2.25 petrol has a Weber 34ICH 2/350 Carb fitted (without cutoff solenoid).
I've stripped and rebuilt it with Weber refurb kit, and checked that all the configurable parts (valves, jets etc) are the right ones (based on the specs for a "Weber Conversion" kit), but do you think I can set up the cursed thing?
Engine starts first crank every time, and once warmed up will idle nicely.
The instructions for setting up are;
Initial conditions; Set Idle speed screw 1.5T from stop & Mixture screw 2T from Stop.
With engine warm;
Screw in mix screw until engine starts to run rough then screw out until smooth running.
Continue to back out until no further change or engine starts runing rough again.
Screw back in to sweet spot.
Adjust idle screw to keep idle speed around 500 rpm.
The problem I have is that as I wind out the mix screw, the engine just keep getting faster, it never seems to reach a point where there is no further improvement or a degredation.
What am I missing?
I feel as though if I turn it much further, it'll come out!
Re: Weber 34ICH 2/350 Carburettor Set-up
Firstly I know nothing about Weber carburettor but I'm assuming the principle is the same as the Zenith where screwing out the mixture screw richens the mixture in which case the engine reacts as if the choke is pulled out. In your case as it speeds up this would point to an air leak. Try spraying WD40 around the carburettor to manifold gaskets and if the engine speeds up there's your problem. That's the only advice I can offer.
On my Zenith equipped 2.5 petrol engine about a quarter of a turn of the mixture screw either way upsets the engine running.
A vacuum gauge is a worthwhile fitment to ensure a properly set up engine. The second picture shows mine with the engine idling. A high vacuum denotes a healthy set up engine. The first picture shows the manifold connection just below the in line filter.
Paulie
Post by Paulie »
I have a Weber carburettor like yours, rebuilt it like you. However a classic car club I'm a member of, one of the members is a retired mechanic who served his time on series landys and went on to run a successful garage for a bit of background. He told me an easy way to tune the landy, and I've used this method myself.
Turn idle screw until the revs are very low, or the revs won't drop anymore. Turn in the mixture screw until it starts to run rough, then turn it out a 1/4 of a turn. Raise the idle speed to desired rpm. I think I'm on around 700 rpm. Hope that's of some help.
Paulie, is your mechanic mate one of the old school who can time an engine by ear?
700 rpm is a little fast. My 2.5 petrol ticks over so slowly that the ignition warning light stays on yet it will pull itself in reverse up my gently sloping upwards drive on tickover.
Paulie
Post by Paulie »
Neil Bymouth wrote: Wed Nov 18, 2026 8:08 pm Paulie, is your mechanic mate one of the old school who can time an engine by ear?
Hi Neil, it was me that decided on the tickover speed. This happened after I had the distributor reconditioned and after he told me the way he set it, and did so in the middle of Barley Saturday a few years ago whilst waiting in a side street. I'm just mindful that the rpm is enough to work the oil pump efficiently,
