Mystery chassis number
Hi everyone
Asking for a friend (yes, really!) whose IIA restoration project has revealed these numbers painted on the chassis.
262502
Does anyone have any idea what they might signify, please?
(I have a photo but can't seem to insert / attach it to this post)
thanks
Jim
262502
thanks
Jim
Re: Mystery chassis number
Hi Jim,
A photo would be useful. That does look like the format for Land Rover Part number of perhaps the chassis...
Need to see a picture.
Thanks for the prompt response.
I think I've figured out how to attach the photo - can you see the attached?
Cheers
Jim
Cheers
Jim
- Series IIA chassis number.JPEG (374.28 KiB) Viewed 21469 times
The first digit looks more like an Eight to me .
Thanks, Carlos
Yes, it could be....
I've checked that as a part number and it doesn't exist. It's been stencilled so I wonder if there's a military connection.
The white-painted number is almost certainly not a factory chassis or casting number, but an internal or post-factory marking. Numbers like this were commonly used as factory assembly/batch tracking codes, workshop or restoration job numbers, fleet inventory IDs, or galvanising/refurbishment identifiers added during later work. They were applied for logistics and record-keeping, not for vehicle identity, which is why they’re usually painted or stenciled rather than stamped into the metal.
'53 Series 1 80"
'16 Defender 90" Heritage
'23 Defender 110" 75th
Thanks, Gunner TM. That makes sense.
Cheers
Jim
Cheers
Jim
GunnarTM wrote: Fri Jan 23, 2026 7:53 pm The white-painted number is almost certainly not a factory chassis or casting number, but an internal or post-factory marking. Numbers like this were commonly used as factory assembly/batch tracking codes, workshop or restoration job numbers, fleet inventory IDs, or galvanising/refurbishment identifiers added during later work. They were applied for logistics and record-keeping, not for vehicle identity, which is why they’re usually painted or stenciled rather than stamped into the metal.
